Compilation : erreur cmake sur arm64 7 years 5 months ago #462
Voici le texte de l'erreur
_________________________________
CMake Warning at data/tr/CMakeLists.txt:3 (FIND_PACKAGE):
By not providing "FindQt5LinguistTools.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"Qt5LinguistTools", but CMake did not find one.
Could not find a package configuration file provided by "Qt5LinguistTools"
with any of the following names:
Qt5LinguistToolsConfig.cmake
qt5linguisttools-config.cmake
Add the installation prefix of "Qt5LinguistTools" to CMAKE_PREFIX_PATH or
set "Qt5LinguistTools_DIR" to a directory containing one of the above
files. If "Qt5LinguistTools" provides a separate development package or
SDK, be sure it has been installed.
CMake Error at data/tr/CMakeLists.txt:8 (qt5_create_translation):
Unknown CMake command "qt5_create_translation".
_________________
Les paquets installés sont
libnova-dev is already the newest version (0.16-2).
libopenjp2-7-dev is already the newest version (2.3.0-1).
libproj-dev is already the newest version (4.9.3-2).
build-essential is already the newest version (12.4ubuntu1).
cmake is already the newest version (3.10.2-1ubuntu2).
libbz2-dev is already the newest version (1.0.6-8.1).
zlib1g-dev is already the newest version (1:1.2.11.dfsg-0ubuntu2).
git is already the newest version (1:2.17.1-1ubuntu0.4).
libpng-dev is already the newest version (1.6.34-1ubuntu0.18.04.2).
qt5-default is already the newest version (5.9.5+dfsg-0ubuntu2).
Compilation : erreur cmake sur arm64 7 years 5 months ago #463
OK
Erreur trouvée après un coup de Google
il faut installer également qttools5-dev
Il faudrait changer la doc ci-dessous (et corriger cmake .. en cmake ../ ;-) )
github.com/opengribs/XyGrib/blob/master/INSTALL.md
Compilation : erreur cmake sur arm64 7 years 5 months ago #464
Bon, maintenant une erreur dans le link
_____________
[100%] Linking CXX executable XyGrib
cd /home/pytheas/XyGrib/build/src && /usr/bin/cmake -E cmake_link_script CMakeFiles/XyGrib.dir/link.txt --verbose=1
/usr/bin/c++ -Wall -fPIC -rdynamic CMakeFiles/XyGrib.dir/Astro.cpp.o CMakeFiles/XyGrib.dir/BoardPanel.cpp.o CMakeFiles/XyGrib.dir/ColorScale.cpp.o CMakeFiles/XyGrib.dir/ColorScaleWidget.cpp.o CMakeFiles/XyGrib.dir/DataColors.cpp.o CMakeFiles/XyGrib.dir/DataMeteoAbstract.cpp.o CMakeFiles/XyGrib.dir/DataPointInfo.cpp.o CMakeFiles/XyGrib.dir/DataQString.cpp.o CMakeFiles/XyGrib.dir/DateChooser.cpp.o CMakeFiles/XyGrib.dir/DialogBoxColumn.cpp.o CMakeFiles/XyGrib.dir/DialogFonts.cpp.o CMakeFiles/XyGrib.dir/DialogGraphicsParams.cpp.o CMakeFiles/XyGrib.dir/DialogLoadGRIB.cpp.o CMakeFiles/XyGrib.dir/DialogProxy.cpp.o CMakeFiles/XyGrib.dir/DialogSelectMetar.cpp.o CMakeFiles/XyGrib.dir/DialogServerStatus.cpp.o CMakeFiles/XyGrib.dir/DialogUnits.cpp.o CMakeFiles/XyGrib.dir/FileLoaderGRIB.cpp.o CMakeFiles/XyGrib.dir/Grib2Plot.cpp.o CMakeFiles/XyGrib.dir/Grib2Reader.cpp.o CMakeFiles/XyGrib.dir/Grib2Record.cpp.o CMakeFiles/XyGrib.dir/GribAnimator.cpp.o CMakeFiles/XyGrib.dir/GribPlot.cpp.o CMakeFiles/XyGrib.dir/GribReader.cpp.o CMakeFiles/XyGrib.dir/GribRecord.cpp.o CMakeFiles/XyGrib.dir/GriddedPlotter.cpp.o CMakeFiles/XyGrib.dir/GriddedReader.cpp.o CMakeFiles/XyGrib.dir/GriddedRecord.cpp.o CMakeFiles/XyGrib.dir/ImageWriter.cpp.o CMakeFiles/XyGrib.dir/IrregularGridded.cpp.o CMakeFiles/XyGrib.dir/IsoLine.cpp.o CMakeFiles/XyGrib.dir/LonLatGrid.cpp.o CMakeFiles/XyGrib.dir/LongTaskMessage.cpp.o CMakeFiles/XyGrib.dir/LongTaskProgress.cpp.o CMakeFiles/XyGrib.dir/MainWindow.cpp.o CMakeFiles/XyGrib.dir/MapDrawer.cpp.o CMakeFiles/XyGrib.dir/MenuBar.cpp.o CMakeFiles/XyGrib.dir/Metar.cpp.o CMakeFiles/XyGrib.dir/MeteoTable.cpp.o CMakeFiles/XyGrib.dir/MeteoTableWidget.cpp.o CMakeFiles/XyGrib.dir/MeteotableOptionsDialog.cpp.o CMakeFiles/XyGrib.dir/SkewT.cpp.o CMakeFiles/XyGrib.dir/SkewTWindow.cpp.o CMakeFiles/XyGrib.dir/Terrain.cpp.o CMakeFiles/XyGrib.dir/Therm.cpp.o CMakeFiles/XyGrib.dir/main.cpp.o CMakeFiles/XyGrib.dir/moc_Astro.cpp.o CMakeFiles/XyGrib.dir/moc_BoardPanel.cpp.o CMakeFiles/XyGrib.dir/moc_ColorScale.cpp.o CMakeFiles/XyGrib.dir/moc_ColorScaleWidget.cpp.o CMakeFiles/XyGrib.dir/moc_DataColors.cpp.o CMakeFiles/XyGrib.dir/moc_DataMeteoAbstract.cpp.o CMakeFiles/XyGrib.dir/moc_DataPointInfo.cpp.o CMakeFiles/XyGrib.dir/moc_DataQString.cpp.o CMakeFiles/XyGrib.dir/moc_DateChooser.cpp.o CMakeFiles/XyGrib.dir/moc_DialogBoxColumn.cpp.o CMakeFiles/XyGrib.dir/moc_DialogFonts.cpp.o CMakeFiles/XyGrib.dir/moc_DialogGraphicsParams.cpp.o CMakeFiles/XyGrib.dir/moc_DialogLoadGRIB.cpp.o CMakeFiles/XyGrib.dir/moc_DialogProxy.cpp.o CMakeFiles/XyGrib.dir/moc_DialogSelectMetar.cpp.o CMakeFiles/XyGrib.dir/moc_DialogServerStatus.cpp.o CMakeFiles/XyGrib.dir/moc_DialogUnits.cpp.o CMakeFiles/XyGrib.dir/moc_FileLoaderGRIB.cpp.o CMakeFiles/XyGrib.dir/moc_Grib2Plot.cpp.o CMakeFiles/XyGrib.dir/moc_Grib2Reader.cpp.o CMakeFiles/XyGrib.dir/moc_Grib2Record.cpp.o CMakeFiles/XyGrib.dir/moc_GribAnimator.cpp.o CMakeFiles/XyGrib.dir/moc_GribPlot.cpp.o CMakeFiles/XyGrib.dir/moc_GribReader.cpp.o CMakeFiles/XyGrib.dir/moc_GribRecord.cpp.o CMakeFiles/XyGrib.dir/moc_GriddedPlotter.cpp.o CMakeFiles/XyGrib.dir/moc_GriddedReader.cpp.o CMakeFiles/XyGrib.dir/moc_GriddedRecord.cpp.o CMakeFiles/XyGrib.dir/moc_ImageWriter.cpp.o CMakeFiles/XyGrib.dir/moc_IrregularGridded.cpp.o CMakeFiles/XyGrib.dir/moc_IsoLine.cpp.o CMakeFiles/XyGrib.dir/moc_LonLatGrid.cpp.o CMakeFiles/XyGrib.dir/moc_LongTaskMessage.cpp.o CMakeFiles/XyGrib.dir/moc_LongTaskProgress.cpp.o CMakeFiles/XyGrib.dir/moc_MainWindow.cpp.o CMakeFiles/XyGrib.dir/moc_MapDrawer.cpp.o CMakeFiles/XyGrib.dir/moc_MenuBar.cpp.o CMakeFiles/XyGrib.dir/moc_Metar.cpp.o CMakeFiles/XyGrib.dir/moc_MeteoTable.cpp.o CMakeFiles/XyGrib.dir/moc_MeteoTableWidget.cpp.o CMakeFiles/XyGrib.dir/moc_MeteotableOptionsDialog.cpp.o CMakeFiles/XyGrib.dir/moc_SkewT.cpp.o CMakeFiles/XyGrib.dir/moc_SkewTWindow.cpp.o CMakeFiles/XyGrib.dir/moc_Terrain.cpp.o CMakeFiles/XyGrib.dir/moc_Therm.cpp.o CMakeFiles/XyGrib.dir/moc_main.cpp.o CMakeFiles/XyGrib.dir/moc_DataDefines.cpp.o CMakeFiles/XyGrib.dir/moc_DialogBoxBase.cpp.o CMakeFiles/XyGrib.dir/moc_FileLoader.cpp.o CMakeFiles/XyGrib.dir/moc_RegularGridded.cpp.o CMakeFiles/XyGrib.dir/moc_RegularGriddedPlot.cpp.o CMakeFiles/XyGrib.dir/moc_Stylesheet.cpp.o -o XyGrib g2clib-1.6.0/libg2clib.a GUI/libgui.a util/libutil.a map/libmap.a -Wl,-Bstatic -lnova -Wl,-Bdynamic /usr/lib/aarch64-linux-gnu/libopenjp2.so.7 /usr/lib/aarch64-linux-gnu/libQt5Network.so.5.9.5 /usr/lib/aarch64-linux-gnu/libQt5Xml.so.5.9.5 /usr/lib/aarch64-linux-gnu/libQt5PrintSupport.so.5.9.5 -lbz2 -lz -lproj -lpng -lz GUI/libgui.a util/libutil.a -lproj -lpng /usr/lib/aarch64-linux-gnu/libQt5Widgets.so.5.9.5 /usr/lib/aarch64-linux-gnu/libQt5Gui.so.5.9.5 /usr/lib/aarch64-linux-gnu/libQt5Core.so.5.9.5
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/libnova.a(julian_day.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol `__stack_chk_guard@@GLIBC_2.17' which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/libnova.a(julian_day.o)(.text+0x4): unresolvable R_AARCH64_ADR_PREL_PG_HI21 relocation against symbol `__stack_chk_guard@@GLIBC_2.17'
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
src/CMakeFiles/XyGrib.dir/build.make:2848: recipe for target 'src/XyGrib' failed
make[2]: *** [src/XyGrib] Error 1
make[2]: Leaving directory '/home/pytheas/XyGrib/build'
CMakeFiles/Makefile2:102: recipe for target 'src/CMakeFiles/XyGrib.dir/all' failed
make[1]: *** [src/CMakeFiles/XyGrib.dir/all] Error 2
make[1]: Leaving directory '/home/pytheas/XyGrib/build'
Makefile:132: recipe for target 'all' failed
make: *** [all] Error 2
Compilation : erreur cmake sur arm64 6 years 11 months ago #603
I could not find the solution to this problem on the internet, therefore I post it here, while it is unrelated to XyGrib (and in the wrong language, excusez moi).
If you run into this problem, you'll have to build libnova from source on Ubuntu 18.04 for arm64.
Something like (using root, fakeroot or another method):
apt-get --compile source libnova-0.16-0
dpkg -i libnova-dev-0.16-2_arm64.deb
This solves the "-fPIC" problem, the XyGrib compilation can be finished and you can proceed with installation.
Pytheas wrote: Bon, maintenant une erreur dans le link
_____________
< remove unnecessary parts >
Last edit: by hreuver.
