Where are language files to be installed? 7 years 3 months ago #536
  • COOGOR
  • COOGOR's Avatar Topic Author
In fact, at start it asks to select language, but at the end it is completely in English.
Where should the tarball for languages go?
/usr/share/XyGrib/data/languages maybe?
Where are language files to be installed? 7 years 3 months ago #537
/usr/share/openGribs/XyGrib/data/tr or
/usr/local/share/openGribs/XyGrib/data/tr
files .ts are the text files to update translation (there is a need on most language except english, french, spanish, hebrew ... see github.com/dominiquehausser/XyGrib/issues/1
files .tm are the one used by XyGrib
Where are language files to be installed? 7 years 3 months ago #540
@Coogor,
The language files are included in the "data" folder structure and unless you wish to change anything there is no need to touch them.
If the data structure is not found (your other post touched on this) then the language files will also be missing.
Time to create page: 0.024 seconds
