Missing data in ICON Model 6 years 11 months ago #599
  • kocki
  • kocki's Avatar Topic Author
there are no weather data in the donwload of ICON Athmospheric model, only wind arrows, but nothing else.
Any idea?
Last edit: by kocki.
Missing data in ICON Model 6 years 11 months ago #600
I can see the arrow of wind, this means that data are there.
It seems that no map from the menu "Weather map" is not selected.
PS : Ich kan sehen dass die deutche Übersetzung istnicht up-to-date... wenn Sie ein bissen Zeit haben, es wäre schön die Übersetzung arbeiten : github.com/dominiquehausser/XyGrib/issues/1); das wird sicher viel helfen.
Missing data in ICON Model 6 years 11 months ago #601
  • kocki
No I can't select a weather map, all is greyed.
In the second picture of my first post you can see the details of downloaded data, there are no weather details included in the downloaded file.
Missing data in ICON Model 6 years 11 months ago #602
I just test downloading ICON model data, there is apparently a problem at the level of the server. We are looking at this problem.
In the meantime, you can use ICON-EU, which work
The following user(s) said Thank You: kocki
Missing data in ICON Model 6 years 11 months ago #604
The ICON Global data should be back in production without more problems.
I tried to downscale the production server for DWD and Meteo France products but it turned out that the ICON global data is too demanding for a smaller setup as it has a huge volume (altitude data) and it all requires remapping from the unique grid used by ICON global. A single cpu could not handle this.
I initially used a large server at my location (free) but the network demands were too high and download and upload speeds were not acceptable.
The solution was to revert back to the larger AWS EC2 cloud (t2 medium) in the Frankfurt region. (This is the only region that gets reasonable downloads from Meteo France).
In short - its quite a balancing act and we will have to bear the cost of the larger virtual cloud server.
Missing data in ICON Model 6 years 11 months ago #606
  • kocki
Thank you David,
all is working fime again.
Gerd
