Build fail against qt 5.15 / gcc10 6 years 4 months ago #758
  • COOGOR
  • COOGOR's Avatar Topic Author
Morning Gents,
build against our rolling release Tumbleweed fails with the error:
[   72s] cd /home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/build/src && /usr/bin/c++  -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_NO_DEBUG -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_XML_LIB -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/build/src -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src -I/usr/include/openjpeg-2.3 -I/usr/include/libpng16 -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/build/CMakeFiles/include -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/util -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/map -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/build/src/map/map_autogen/include -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/GUI -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/build/src/GUI -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/g2clib-1.6.0 -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/map/.. -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/map/../util -I/home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/map/../GUI -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -isystem /usr/lib64/qt5/mkspecs/linux-g++ -isystem /usr/include/qt5/QtNetwork -isystem /usr/include/qt5/QtPrintSupport -isystem /usr/include/qt5/QtXml  -O2 -Wall -D_FORTIFY_SOURCE=2 -fstack-protector-strong -funwind-tables -fasynchronous-unwind-tables -fstack-clash-protection -Werror=return-type -flto=auto -g -DNO_UPDATE=1 -DOPENSUSE=1 -Wall -fPIC -O2 -g -DNDEBUG   -fPIC -std=gnu++11 -o CMakeFiles/XyGrib.dir/SkewT.cpp.o -c /home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/SkewT.cpp
[   72s] In file included from /home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/MeteoTableWidget.h:27,
[   72s]                  from /home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/MeteoTable.h:27,
[   72s]                  from /home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/MeteoTable.cpp:27:
[   72s] /home/abuild/rpmbuild/BUILD/XyGrib-1.2.6.1/src/SkewT.h:38:25: error: invalid use of incomplete type 'class QPainterPath'
[   72s]    38 | class PersPath : public QPainterPath
[   72s]       |                         ^~~~~~~~~~~~
(Next to this there is a bunch of warnings - see build.opensuse.org/package/live_build_lo...SE_Tumbleweed/x86_64 )
Can I kindly point your attention to this?
Thanks!
Last edit: by COOGOR. Reason: typo corrected
Build fail against qt 5.15 / gcc10 6 years 3 months ago #767
  • COOGOR
Hm, nobody an idea or patch?
Build fail against qt 5.15 / gcc10 6 years 3 months ago #769
In my understanding there's a PR:
github.com/opengribs/XyGrib/pull/255
Build fail against qt 5.15 / gcc10 6 years 3 months ago #770
  • COOGOR
Ah, did of course not look at github.
That fixes it, thanks!
