libpng warning: iCCP: known incorrect sRGB profile 8 years 5 months ago #50
  • COOGOR
  • COOGOR's Avatar Topic Author
I've compiled YxGrib for openSUSE and installed it on Tumbleweed, the rolling release. On start I get the following message:
docb@T520:~/ > XyGrib
Empty filename passed to function
Not sure if this is important....
libpng warning: iCCP: known incorrect sRGB profile 8 years 5 months ago #53
Can you please confirm that the "data" folder tree exists in the folder where the executable file is.
It sounds as if the colors files are not seen.
libpng warning: iCCP: known incorrect sRGB profile 8 years 5 months ago #54
If possible please download the AppImage version for Linux and check it it runs without any error message. With this package all dependencies are included and pre-tested. Installation does not change or add anything on the new host.
libpng warning: iCCP: known incorrect sRGB profile 8 years 5 months ago #55
  • COOGOR
T520:/home/docb # dir /usr/lib64/XyGrib/
insgesamt 4
drwxr-xr-x 1 root root 12 18. Mai 08:24 bin
drwxr-xr-x 1 root root 56 18. Mai 08:24 data
drwxr-xr-x 1 root root 50 18. Mai 08:24 grib
-rwxr-xr-x 1 root root 47 27. Apr 21:42 XyGrib
T520:/home/docb # /usr/lib64/XyGrib/XyGrib
QStandardPaths: wrong ownership on runtime directory /run/user/1001, 1001 instead of 0
libpng warning: iCCP: known incorrect sRGB profile 8 years 5 months ago #56
Can you please try:
1. install under your home/user and see if the issue continues.
2. Try the AppImage version
libpng warning: iCCP: known incorrect sRGB profile 8 years 4 months ago #58
  • COOGOR
Hello David,
I tried the Appimage version on Leap 15:
axel@southpole:~/XyGrib-1.0.1-AppImage> ./XyGrib-x86_64.AppImage
QXcbConnection: XCB error: 3 (BadWindow), sequence: 629, resource id: 27511397, major code: 40 (TranslateCoords), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 6986, resource id: 27513172, major code: 40 (TranslateCoords), minor code: 0
Application itself is working (as in the first case as well), dont know if the message has any impact
Time to create page: 0.033 seconds
