Unable to build on ubuntu 18.04 and rpi over Raspbian stretch 8 years 3 months ago #69
tu wrote: Same error on both.
Dependencies issue:
Unable to find libjasper-dev
Cannot instal dependencies. Cannot build.
I had the point to the github, as this is a real problem since the package has been remove from the distro (it was present till 16.10), to find a solution.
Update : solution has been found by Menno Tammens (see github.com/MennoTammens/XyGrib/commit/ea...2e885a1039150660b671). I tested it and it work very well.
This will be included in the source files in the future.
Be patient as there now a lot of job done on the server side to include new sources of data.
Unable to build on ubuntu 18.04 and rpi over Raspbian stretch 8 years 3 months ago #70
  • tu
  • tu's Avatar Topic Author
I forgot to tell you that in order to build it in the RPI it was also necessary to modify the make -j6 values of the main makefile by make -j2. Otherwise the Rpi would freeze during build.
