Issue running XyGrib 1.1.0 over OpenPlotter 8 years 3 months ago #71
  • tu
  • tu's Avatar Topic Author
As I mentioned in the other thread I was finally able to build XyGrib for Raspberry Pi in OpenPlotter.
After the success with version 1.0.1 I went to work to compile version 1.1.0 of XyGrib. The compilation worked well following the same steps and modifying the same files. The problem arises when running version 1.1.0. Everything seems to work fine but when you request the grib download, an error message with no text is showed and the download does not take place.
Do any of you know what's going on with the new version and why can't download the files?
Issue running XyGrib 1.1.0 over OpenPlotter 8 years 3 months ago #72
The grib server for the new version is still work in progress and may return errors or be non-responsive while being updated.
The new server will be in steady service when the new version is released.
There have been changes to both the XyGrib client and the server in the last 24 hours. I suggest to rebuild and try again with the updated version (now named 1.0.99 as 1.1.0 should be reserved for the release.
The following user(s) said Thank You: tu
Issue running XyGrib 1.1.0 over OpenPlotter 8 years 3 months ago #73
  • tu
OK Davidgal. Thanks a lot. I will try and share the results here.
Issue running XyGrib 1.1.0 over OpenPlotter 8 years 3 months ago #74
  • tu
I have already compiled version 1.0.99 in OPlotter and it works like a charm. Everything seems to work perfectly and I would even say it is lighter and faster in all processes. I love it. I like the new colors too.
Thanks for the great job.
