No maps at all on Mac 8 years 4 weeks ago #199
I ran the original version of XY Grib on my MacBook Air by downloading the .pkt file and it all worked rather like ZY Grib.
When I tried to update my xy grib by downloading the file
Mac Installer Package - XyGrib_mac_1.1.1.pkg (24.7MB)
The program did not work.
Help?
I got this message:
Process: XyGrib [612]
Path: /Applications/XyGrib/XyGrib.app/Contents/MacOS/XyGrib
Identifier: XyGrib
Version: 1.1.1 (1.1.1)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: XyGrib [612]
User ID: 501
Date/Time: 2018-09-29 06:29:59.037 +0100
OS Version: Mac OS X 10.13.6 (17G65)
Report Version: 12
Anonymous UUID: 289CBA73-3CF9-6CED-ABF1-EA2500A7E200
Time Awake Since Boot: 220 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /Library/Frameworks/PROJ.framework/Versions/4B/PROJ
Referenced from: /Applications/XyGrib/XyGrib.app/Contents/MacOS/XyGrib
Reason: image not found
Binary Images:
0x107359000 - 0x107821ff7 +XyGrib (1.1.1 - 1.1.1) <DC5283D7-5CFB-367E-AFF9-7DAE934BB4AB> /Applications/XyGrib/XyGrib.app/Contents/MacOS/XyGrib
0x1078c4000 - 0x1079caffb +org.qt-project.QtNetwork (5.11 - 5.11.2) <CECCA1C7-8764-3738-8CC9-3F0ECC0BDCC6> /Applications/XyGrib/XyGrib.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
0x107a17000 - 0x107a48ff7 +org.qt-project.QtXml (5.11 - 5.11.2) <29B95D77-571D-3722-8501-5E68B02D25BB> /Applications/XyGrib/XyGrib.app/Contents/Frameworks/QtXml.framework/Versions/5/QtXml
0x107a5a000 - 0x107a84ff3 +org.qt-project.QtPrintSupport (5.11 - 5.11.2) <7144779C-2F7A-3DD3-9D5F-9F5B74022C0F> /Applications/XyGrib/XyGrib.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
0x111d4b000 - 0x111d95acf dyld (551.4) <8A72DE9C-A136-3506-AA02-4BA2B82DCAF3> /usr/lib/dyld
0x7fff75ba8000 - 0x7fff75bb5ffb libbz2.1.0.dylib (38) <0A5086BB-4724-3C14-979D-5AD4F26B5B45> /usr/lib/libbz2.1.0.dylib
0x7fff77a50000 - 0x7fff77a62ffb libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
Model: MacBookAir6,2, BootROM MBA61.0107.B00, 2 processors, Intel Core i5, 1.3 GHz, 4 GB, SMC 2.13f15
Graphics: Intel HD Graphics 5000, Intel HD Graphics 5000, Built-In
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3230554638454455302D474E2D4620
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3230554638454455302D474E2D4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.77.37.31.1a9)
Bluetooth: Version 6.0.7f10, 3 services, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SD0256F, 251 GB
USB Device: USB 3.0 Bus
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Air, Apple Inc., 23.6
What should I do to get Xy Grib working.
Michael Hodin
No maps at all on Mac 8 years 4 weeks ago #200
We are looking into it via an open issue in github.
Thanks for your patience.
No maps at all on Mac 8 years 4 weeks ago #201
I fix has been made to ensure that the missing library is available for XyGrib on MacOS.
There is an updated version XyGrib_mac_1.1.1-b.pkg available for download on this site or on Github. Please try it.
The fix has been tried on a fresh install of MacOS 10.13.6 (High Sierra) and it installed and ran OK.
Please note that we will shortly release version 1.1.2 which fixes some known issues in 1.1.1.
No maps at all on Mac 8 years 3 weeks ago #202
Verstion 1.1.2 has been rleased. Please try it on your Mac.
Note that it has a new install system. You only need to use it once. All future updates can be retrieved via the maintenance tool that it install together with the application.
Please let us know if all is well.
Tnks,
