version 1.2 unstable charts 7 years 10 months ago #298
first, thanks for all the excellent work in v 1.2. I have one irritating but not fatal problem: Mac OS 10.14:- the charts aren't stable, viz, a chart will collapse to its minimum size at some random moment when the mouse/touchpad is used. Not always, but frequently. Not desperate, as you can enlarge it again but it's very frustrating. I'm using xygrib on both a MacBook Air, (touchpad), and a Mac Mini, (bluetooth mouse), and this happens on both. I can't make this happen in a predictable way. Impossible problem but any inspiration on what might avoid it would add to my thanks for how incredibly useful this app is
Jon
version 1.2 unstable charts 7 years 10 months ago #299
I will open an issue on this but it may be difficult to fix without the ability to replicate what you experienced.
version 1.2 unstable charts 7 years 10 months ago #300
  • Ruud
  • Ruud's Avatar
Hello David,
I did some tests on my Macbook and found out that this is probably related to the scrolling function of the touchpad. Everything works fine with a mouse or with just one finger on the touchpad. However as soon as a second finger is added the map behaves as Evariste descripes. So it looks like XyGrib for Mac overreacts a bit when it detects a command to zoom from the touchpad. Zooming with the mouse wheel works perfectly ok.
Hope this helps to find a solution...
Ruud
version 1.2 unstable charts 7 years 10 months ago #301
Great work Ruud. Many thanks for taking the time to check this. Tried your analysis and completely agree. Now i know not to zoom wth 2 finger touch i can relax !
version 1.2 unstable charts 7 years 10 months ago #302
Great!
Thanks Ruud. Now I've got something to work on. I'll try and fix it.
