Pallet colors 7 years 6 months ago #332
Hi! Congratulations for this awesome work!
Is it possible to change the pallet colors?
Pallet colors 7 years 6 months ago #333
Hi Lord of the Weather and welcome to the forum.
Yes, it is possible to edit the color maps for the various variables.
You need to find where the /openGribs/XyGrib/data/colors folder is located on your system. On a current Windows machine it will most likely be under <user>\AppData\Roaming\.
In the colors folder there are text files for each weather variable. These files contain the color values.
Best to make a safety copy of a file before you edit it.
Each line starts with the meteo parameter value and then 3 RGB values for that range. Parameter values and corresponding RGB values can be edited.
Have fun
The following user(s) said Thank You: Lord of the Weather, neavilag
Pallet colors 7 years 6 months ago #334
Thank you very much David!
All the best and a Happy New Year!
Pallet colors 7 years 5 months ago #386
I am trying to locate this folder colors but cannot find in my installation
XyGrib : GRIB files visualization
Version : 1.2.4 2019-02-05
Am I not searching correctly?
Pallet colors 7 years 5 months ago #388
Hi neavilag,
The colors folder is not with the application itself but with your own Application Support are where user data should normally be kept.
In your home folder change folders to -> Library -> Application Support -> openGribs -> XyGrib -> data - colors
I hope this helps you out.
The following user(s) said Thank You: neavilag
Pallet colors 7 years 5 months ago #390
Thanks, I was looking in the wrong place, is ~/Library ....
