The German Stroemungsvorhersagen data 8 years 6 months ago #18
  • Hill
  • Hill's Avatar Topic Author
Thank you very much for modifying the program so as to be able to read this data. This is the only program I kn ow of which can read this data correctly.
Unfortunately you've used dark blue arrows on a slightly less dark blue background. Could I suggest changing the colour scheme a little?
The German Stroemungsvorhersagen data 8 years 6 months ago #19
Hill wrote: Unfortunately you've used dark blue arrows on a slightly less dark blue background. Could I suggest changing the colour scheme a little?
You probably forgot to select map of currents in the menu "Sea" (see attached image
The German Stroemungsvorhersagen data 8 years 6 months ago #20
  • Hill
Thanks very much.
That is an invaluable resource for people sailing to the Baltic .
I am also involved in the revision of Imray's Cruising Guide to Germany & Denmark, and will give it a plug there.
The German Stroemungsvorhersagen data 8 years 5 months ago #51
Where did you get the german gribs from?
Or more precisely - there is currently no mean to automatically download them into XyGrib, so you added them manually, correct?
Last edit: by COOGOR.
The German Stroemungsvorhersagen data 8 years 5 months ago #52
  • Hill
Goto:
ftp://ftp.bsh.de/Stroemungsvorhersagen/grib2/
and you'll find the links at the bottom of that page. You can download them then yes, you need to open them from which directory you've downloaded them to.
The German Stroemungsvorhersagen data 8 years 4 months ago #59
Had a look at it, thank you!
Having the currents as overlay would be great in qtVLM....
