The Zygrib GFS model upgrade? il y a 7 ans 3 mois #524
  • RJCook
  • Portrait de RJCook Auteur du sujet
Has the GFS model Zygrib uses been upgraded to the new FV3 version?
The Zygrib GFS model upgrade? il y a 7 ans 3 mois #525
GFS F3 is the only model available I think.
Some modification on the code have been done in XyGrib to benefit of this change and being able to show correct values of data.
For Zygrib, you have to ask on the forum of Zygrib
The Zygrib GFS model upgrade? il y a 7 ans 3 mois #526
Just to add some more information:
On June the 12th XyGrib switched to using the FV3 version of GFS (v15.1).
The older version is still available on a parallel NOAA server but we are not using it any more.
The new version, being non-hydrostatic, has some new meteorological parameters. The one most applicable for sailing forecasts is "Reflectivity".
The option to download and display reflectivity for GFS has been added in the v1.2.6 release of XyGrib
Please note that zyGrib still exists and it can be found at zygrib.org
The Zygrib GFS model upgrade? il y a 7 ans 3 mois #533
How about add 2 degrees of resolution for GFS models?
The Zygrib GFS model upgrade? il y a 7 ans 3 mois #534
Something to consider for some future release.
Is it not simpler to get 2 degree gfs gribs from saildocs.com?
