HRRR Model il y a 6 ans 11 mois #596
Any plans to add the HRRR model to your server? I know this model is restricted to continental US (CONUS) but the GRIB2 data is made publically available by NOAA
rapidrefresh.noaa.gov/hrrr/
Rik
HRRR Model il y a 6 ans 11 mois #597
We will consider adding it.
There may be a issue of volume (and subsequent server resources). Needs to be examined.
HRRR Model il y a 6 ans 11 mois #598
Thanks David!
What is a realistic time frame for adding a NWP model like HRRR to your server?
Rik
HRRR Model il y a 6 ans 11 mois #605
Next Xygrib version should be able to read HRRR files (Lambert Conformal projection) and NOAA site offers a sub-setter, maybe Xygrib could download these GRIB directly from NOAA?
Caveats:
- Sub-setter doesn't compress data.
- They change query layout from time to time.
Blend model could be interesting though, there's no sub-setter for it.
Sample in Xygrib:
Stereopolar, Lambert and Mercator GRIB.
HRRR Model il y a 6 ans 11 mois #607
With Didier's great work on adding Lamberth projection, XyGrib opens up a number of grib sources without the need for converting projection as we currently do with NAM CONUS.
Progress is, however, a bit slow as I need to get a thesis completed but we will get there.
HRRR Model il y a 6 ans 10 mois #633
Progress is good...
I have another question related to HRRR...The model does not have a field for the Aviation Flight Rules (as defined by the FAA). The flight rules ca be calculated from two parameters which are in the model i.e. ceiling and visibility. My question is if your software allows me to create a new field/parameter and add it to the GRIB2 dataset. Please advise.
Rik
Temps de génération de la page : 0.061 secondes
