I can not click on the pressure levels they wont work in NAM Mode only Surface il y a 6 ans 4 mois #722
Does have anyone have any issues with the software where they can only click on the surface parameters to download grib files. The upper air levels boxes when I try to click on them wont work in the NAM Model. Any help? I am running win10 64 bit. Maybe there are some settings that need to be made when I download grib files for forecast upper air as well.
Glad to join your group.
Thanks!
Paul K
Meteorologist.
South Florida USA.
I can not click on the pressure levels they wont work in NAM Mode only Surface il y a 6 ans 4 mois #723
You can choose only data that are available on the server of XyGrib. For local level data, like NAM, Arome, etc. the reason is also that the number of data is huge and it will use too much bandwith and server resources to manage them.
Of course if you get them from elsewhere and they are in a format that can be read with XyGrib, no problem.
For memory, the NAM data use another projection and need first to be converted to be visualise properly whith XyGrib.
Les utilisateur(s) suivant ont remercié: wxwatch
I can not click on the pressure levels they wont work in NAM Mode only Surface il y a 6 ans 4 mois #724
I appreciate the fast response. I still like the surface data anyway this program rocks!
Paul
I can not click on the pressure levels they wont work in NAM Mode only Surface il y a 6 ans 4 mois #725
I will get the grip files from noaa no problem for the upper air. The surface data grib available from the Xygrib server for this software that you could download is good and fast!!!! to keep track of weather developing near the ground level awesome.!
Temps de génération de la page : 0.037 secondes
