Where are language files to be installed? il y a 7 ans 1 mois #536
  • COOGOR
  • Portrait de COOGOR Auteur du sujet
  • Membre junior
  • Membre junior
  • Remerciements reçus 1
In fact, at start it asks to select language, but at the end it is completely in English.
Where should the tarball for languages go?
/usr/share/XyGrib/data/languages maybe?
Where are language files to be installed? il y a 7 ans 1 mois #537
/usr/share/openGribs/XyGrib/data/tr or
/usr/local/share/openGribs/XyGrib/data/tr
files .ts are the text files to update translation (there is a need on most language except english, french, spanish, hebrew ... see github.com/dominiquehausser/XyGrib/issues/1
files .tm are the one used by XyGrib
Where are language files to be installed? il y a 7 ans 1 mois #540
@Coogor,
The language files are included in the "data" folder structure and unless you wish to change anything there is no need to touch them.
If the data structure is not found (your other post touched on this) then the language files will also be missing.
