erreur bad request il y a 7 ans 1 semaine #574
bonjour
j ai une erreur BAD REQUEST qui revient régulièrement voir image jointe . comment faire pour résoudre ce problème merci
erreur bad request il y a 7 ans 1 semaine #575
I tried Arome 0.025deg at this time and it is downloading well.
It might happen that on occasion there is a bad download from Meteo France as their open data server provides very bad service to say the least.
If you have the problem again, please try a previous cycle (not the "last") or wait for the next cycle to publish.
erreur bad request il y a 7 ans 1 semaine #576
i have tryed with an previous cycle but not match.
the bad request appears alo withe gfs format
i not be sure that the problem came from Meteo france
thanks
jacques
erreur bad request il y a 7 ans 1 semaine #577
OK....
I can see the problem and I was able to replicate it.
You need to request a slightly bigger area. If the requested area is too small the request will fail.
I have listed this to be fixed in the next version.
I hope this helps.
Les utilisateur(s) suivant ont remercié: jacques
erreur bad request il y a 7 ans 1 semaine #578
ALL IS GOOL ;......... GOAL
i have make a bigger area and grib is income
thanks for all
where are you
erreur bad request il y a 7 ans 6 jours #579
Hi Jacques,
The problem was on the grib server side and it has now been fixed.
It is possible to download grib files less than 1x1 degree.
