XyGrib won't compile on Fedora 23 il y a 8 ans 6 mois #41
gcc -c -O3 -g -m64 -I/nwprod/lib/include/ -DUSE_JPEG2000 -DUSE_PNG -D__64BIT__ enc_jpeg2000.c
enc_jpeg2000.c: In function ‘enc_jpeg2000’:
enc_jpeg2000.c:125:10: error: ‘jas_image_t {aka struct <anonymous>}’ has no member named ‘inmem_’
     image.inmem_=1;
make[1]: *** [makefile:89: libg2c.a(enc_jpeg2000.o)] Error 1
make[1]: Leaving directory '/export/source/XyGrib-1.0.1-src/src/g2clib'
make: *** [Makefile:46: XyGrib] Error 2
I found inmem_ was not defined in jasper.h, but I saw a definition in jas_image.h so I added it:
#include "jasper/jas_image.h"
to g2clib/dec_jpeg2000.c
But this did not resolve the issue so I stopped there.
The same failure occurs in ZyGrib so I assume it's a problem with the jasper-devel package having new definitions.
XyGrib won't compile on Fedora 23 il y a 8 ans 6 mois #43
Which version of libjasper do you have installed?
On a completely clean Ubuntu install with libjasper 1.900 XyGrib builds without any problems.
Can you please try and run the Linux AppImage version of XyGrib and let me know if it works on your platform.
XyGrib won't compile on Fedora 27 il y a 8 ans 6 mois #44
$ rpm -qa | grep jasper
jasper-libs-2.0.14-1.fc27.x86_64
jasper-devel-2.0.14-1.fc27.x86_64
Correction, this machine is a Fedora 27 box.
AppImage works fine - I just like to build clean when I can.
XyGrib won't compile on Fedora 27 il y a 8 ans 6 mois #45
It looks like the problem has to do with the newer libjasper version causing conflicting declarations. I will open an issue on GitHub to test with libjasper 2.
XyGrib won't compile on Fedora 27 il y a 8 ans 5 mois #46
It looks like the issue with jasper was also discovered with zyGribs.
aur.archlinux.org/packages/zygrib - blondllblondo on 2017-01-05 suggests commenting out the 'image.inmem_=1;' line.
It would be helpful to put build instructions on the github/wiki for each platform so we can quickly get consistent with the core team.
XyGrib won't compile on Fedora 27 il y a 8 ans 5 mois #47
atseng écrit: It would be helpful to put build instructions on the github/wiki for each platform so we can quickly get consistent with the core team.
As the team is not an expert in all the different OS, we greatly appreciate input from those who know; as much cooperation we have, better will be the product and the quality of documentation.
Of course we will make an effort in helping to "standardize" the presentation.
Temps de génération de la page : 0.036 secondes
