where are stored poi in V1.1.1 il y a 7 ans 8 mois #156
  • kocki
  • Portrait de kocki Auteur du sujet
  • Membre junior
  • Membre junior
I want to copy my poi's from Version 1.1.0 into Version 1.1.1, but I don't find the file in V1.1.1 where the poi's are stored.
Can anybody tell me in which file and directory the poi's are stored?
kocki
where are stored poi in V1.1.1 il y a 7 ans 8 mois #157
The POI are stored in the file xygrib_poi.ini.
In linux it is in the folder for v1.1.1 $HOME/.config instead of for v1.1.0 $HOME/.xygrib/config
For Windows and Mac, no idea anymore (I did not use these OS for years), but with search function you may be able to find the file
Les utilisateur(s) suivant ont remercié: Metbriefer
where are stored poi in V1.1.1 il y a 7 ans 8 mois #158
For Windows you will find them in <USER>\AppData\Local\openGribs\XyGrib\
Les utilisateur(s) suivant ont remercié: kocki, Metbriefer
where are stored poi in V1.1.1 il y a 7 ans 8 mois #159
  • kocki
  • Membre junior
  • Membre junior
Thanks dividgal, I found the file.
kocki
