Meteo Table il y a 7 ans 5 mois #367
  • Ruud
  • Portrait de Ruud Auteur du sujet
  • Remerciements reçus 1
Hello David,
The Mac version crashes when I try to activate the meteotable. I hope the attached error report helps to find the cause.
Ruud
Meteo Table il y a 7 ans 5 mois #369
Thanks Ruud,
We will try and chase it down. I'm opening an issue on github.
Meteo Table il y a 7 ans 5 mois #370
The bug was found and fixed.
The fix will be included in the next release.
Meteo Table il y a 7 ans 5 mois #371
  • Ruud
Thanks David!
