Cannot get MeteoTable on Mac il y a 7 ans 3 mois #385
Hi All, I just testing the new version
XyGrib : GRIB files visualization
Version : 1.2.4 2019-02-05
But when trying to do right click (2 finger on Macbook) the maps zooms out and cannot get the context menu for getting the MeteoTable, anyone having same issue ?
Mac info:
Macbook Air 2018
MacOS Mojave 10.14.3
thanks
Cannot get MeteoTable on Mac il y a 7 ans 3 mois #387
There appears to be an issue connected to the touch pad on Macbooks.
See previous post regarding this opengribs.org/en/forum/xygrib-support/64...-unstable-charts#300
I will reopen an issue on github.
Les utilisateur(s) suivant ont remercié: neavilag
Cannot get MeteoTable on Mac il y a 7 ans 3 mois #389
I was able to partially solve it of someone also has this need.
Add a custom poi, anywhere the mac let you. and then move it with the (Command key + mouse in Mac) where you actually wanted :-/
