installation OnLine echec 8 years 1 month ago #188
j'ai la version 1.1.0 sur opensuse leap 15, je telecharge le script offline, le passe en executable.
Le script se deroule bien sauf vers la fin «Execution failed (Unexpected exit code: 1): "chown -R petrouch:petrouch /home/petrouch/.local/share/openGribs" ».
Auriez vous une idee ?
Merci par avance
Super travail, chapeau bas !!!
installation OnLine echec 8 years 1 month ago #190
Hi Petrouch,
What version of Linux are you using?
There may be an issue in openSuse where the user group is not the same as his name.
The files are currently owned by the root and the application should run OK in spite of the error message. You just won't be able to edit any of the data files (should you be inclined). You can run
sudo chown -R ....
and set the user ownership to the data structure.
installation OnLine echec 8 years 1 month ago #193
Hello
thank for your replay, distribution opensuse LEAP 15.
My commande is : sudo chmod -R 777 openGribs
After this, I launch «XyGrib__Linux_v1.1.1_Offline_Installer» and not ...
installation OnLine echec 8 years 1 month ago #195
Hello, I use kde, sorry
I try with :sudo chown -R 777 openGribs
It's ok and he don't would like to install
I send my log.
Thank for your help, sorry for my english
Last edit: by petrouch.
installation OnLine echec 8 years 1 month ago #197
The problem seems related with your group name.
Try the following :
1. command line 'id' and see name after gid (if different of petrouch, then 2)
2. chown, -R, petrouch:gid, /home/petrouch/.local/share/openGribs
If not different send again a message here, the principal developper will also check (and as he is more qualified than me, he may have the correct answer)
The following user(s) said Thank You: petrouch
installation OnLine echec 8 years 1 month ago #198
Good,
I change my id with :
sudo groupadd petrouch
After I place XyGrib__Linux_v1.1.1_Offline_Installer on my home(petrouch)
Thanks a lot
Time to create page: 0.037 seconds
